my problem is,is that i dont have a big enough radiator in my jeep for the 350. i have a 16.5 x 17.5 core alum. 2 row, one inch core. and a 16" 2200 cfm electric fan. This set up is not working...i get temps in the high 230's at a stop (traffic lights). once driving forward the temps go down to a normal range of 198-210* (forward ram of incoming air) so what radiator do i need? and where can i find one? im guessing i'll need a 3 row. please help, its a daily driver, it's summer, and im tired of running red lights!:bottom: THANKS!
I see you are in detroit
Here we have a place that does truck radiators,semi,dump what ever cars
They rebuild dip whatever,
You must have something like that there
They have delt with every problem you can think of
Plus places like that love jeeps
or check the HOT ROD sites they have too cram radiators
in with there v8s
thanks, i'll check around but im kinda lookin' for some1 to tell me "i run this.....go get it." im in school 8hrs a day and no time to look. so, if some1's running a 350 in their junk, let me know what radiator set up is working for them. thanks-
Minimum 3 row and your fan speed is not high enough, try a 3000+ fan (look up Taurus fan conversion) or get a dual setup and if it still runs hot install a pusher fan in the front of the radiator. I ran a dual setup and had one kick on up to 180* and after that the second would kick in as well to keep it cool.
Here are some helpful links for you, read up and you will know more than you wanted to :rofl:
electric fan, tarus fan, fan, tech - Pirate4x4.Com Bulletin Board
Cooling & Heating at SummitRacing.com: radiators, fans, water pumps, and more
FC-2P Electronic Coolant Fan Control
