Hi guys and girls.
My Jeep 4l engine stops working sometimes when I drive on the road. The engine stops firing. The battery is ok, the rest of the jeep still has power but it stops getting to the spark plugs. I changed the celenoi censer but it is still doing it. I can drive for 50 km without any problem and then I will take it for a 2 km ride and it will shut down every 400 meters.
This started happening after going deep in the water.
Any help would be appreciated.
Thanks in advance.
Sounds like you may have gotten some water where it ought not be. Check inside your distributor cap, and plug wire boots for moisture. If it's injected, check inside the ECU harness, MAP and Throttle Position sensor plugs and anything else that has a wire going to it. Also check for a small wire going to the E-brake pedal has not come loose.
