hello ,
i have 2006 wrangler TJ with a few modifications, the problem is that i do not really know what aftermarket and what "stock" and how things are supposed to look.
what this "tap" do ? its stock or its aftermarket ?
this brake booster is stock ? i also have rear discs brakes how can i tell what the size of the pads ?
I'm pretty sure the tube with the glue stopper did not come that way originally, how should it look like?
looks like Bubba was under your hood...
I see
A manual shut off valve in the heater hose placed to manually shot off hot water flow and make ac colder
A aftermarket alarm electric noise maker
A plugged short hose on a vacuum port
the "Tap" is aftermarket. it will stop hot water from going into your heater core. A long time ago blend doors/heating systems were not isolated from the cab. Stopping water flow into the cab would keep it cooler when the fan was running. Not sure if it's still needed nowadays but could be useful for flushing your heater core.
