Had my 05 rubicon about a week and still trying to learn all about it. 1 - was going to remove doors today but when I took off the little nuts on the bottom of the bolts, the bolts appeared "stuck" in place. Do they just tap out (upward) or is there some kind of trick.... 2 - it looks like the previous owner had some type of rocker panels on it. There are 5 drilled holes along the bottom. What type of panel do y'all use, if you do. I would like to put some type of rocker panels on it. I'm on a little bit of a tight budget, so nothing really fancy. Thanks everyone.
