Pull the fuse :)
Or find out which door is loose/has a bad button. Might be your dash light knob adj too. Just a matter of tracking down the problem part
Administrator
I had that happen with my 06. Mine was a bad switch in the passenger door. I put a piece of thick high density foam tape on the door and problem solved. But as mentioned above it could be something else entirely.
X2
More than likely a door switch.
thank you so much for the info
i will try all the above
im a newb to this website and im glad i sighned up for this forum
Administrator
Well in that case...Welcome to the Forum
