I'm in the process of swapping my D30/35 combo for D44/44 from G2, and adding Currie adjustable arms (all 8). The 44 front is 2.5" longer from the upper mount to the back of the yoke. Am I going to have to shorten front drive shaft, or is that all correctable by extending the arms?
Is it going to be the same on the rear?
The front DS should be fine. But the rear may give you a little trouble with the angle of your DS. Do you have a SYE/CV setup?
Yes, SYE and CV driveshaft are already in. I'm going to have to cut down front driveshaft. It's entirely too long....I had to extend arms out to 17.25" to get it to "fit." Which then made front track bar hit Currielync.
