I think the majority here will tell you to go with the Ace. Especially if you not a heavy duty rock crawler.
I went with the rugged ridge rrc sliders. I had them on in minutes, four bolts per side. They are solid, and they look great.I'm looking at a few options for my new Jeep. The main use will be as a side step, but body panel protection is always a plus. Here are the three I was looking at, I would or any of the 3 in black. Has anyone had any good/bad experiences with them? or know a better way to order them? Thanks!
http://www.realtruck.com/rugged-ridge-rrc-jeep-rock-sliders/R183342P2013Y303MA.html
http://www.realtruck.com/rugged-ridge-side-tube-steps/R183427P2013Y303MA.html
http://www.aceengineeringandfab.com/ACE-JK-Rock-Sliders-4-Door_p_15.html
Edit: I'd also be up for other recommendations!
x2. Took me literally 15-20 minutes total for both sides. No grinding, cutting, or sawing required. They have held up well, i'll upgrade eventually, but these seem to be doing the trick for now.I went with the rugged ridge rrc sliders. I had them on in minutes, four bolts per side. They are solid, and they look great.
Crazy that you mentioned ACE, I'm currently reading the A.C.E. rock rails thread over at JKOwners. Interesting about your issue because I mainly want the rails as a step. I do like how the RRs use all the body bolts for installation instead of the one body bolt per bracket. If someone can confirm that the Rugged Rs can be installed with the Rubi's factory rail I'll be happy to go with RR.I have a 2013 unlimited Rubicon and i bought a set of ace sliders before my Jeep arrived. They look great but they are useless as a step. Honestly they get in the way more than anything. I will keep them to protect from door dings, but i hate them my wife hates and my boys hate them. That goes against what the majority will say but for me and my family they are useless. Not sure if any of the others are better but they can't be any worse.
I thought i should add the build quality is great and they look great but just not a good option if you are wanting a step.
ME TOO!!!If someone can confirm that the Rugged Rs can be installed with the Rubi's factory rail I'll be happy to go with RR.
BTW thanks for the info.
Dammit!Just made a call. Was told Rubi Rails must be removed for the the Rugged Rs.
