these will work fine but where the cable attaches to these is another place that you will have to keep a check on for corrosion
The corrosion can be in the old cables you might want to pull the insulation back a little and if there is eveidence of any corrosion in the cables replace them. Other wise your picture just about does the trick. Good suggestion from above is to tin (use solder) at the ends to go into the new terminal ends.
