1 - 20 of 43 Posts
Thanks for the compliments. I do like stubby bumpers but here in southern louisiana we dont have many rocks. Most trails here are wooded so i wanted a lil more protection if a tree jumps in front of me.
Discussion Starter · #11 ·
I layed out the face on a sheet of plate and cut it with the plasma. The rest was pretty much cut, fit, and weld. Probably have about 20hrs invloved. Im now gonna get it sprayed with line x.
Discussion Starter · #14 ·
That is one heavy ass bumper. Did you buffer the bolts where they mount to the frame?
Yes it is heavy but i like over kill. I can now push pull ram what ever i want with confidence. Im pretty ruff on things lol. The inside the bumper is fully boxed where it bolts up. Grade 8 bolts were put in before boxing it and welded the heads to keep them from turning.
VERY CLEAN! I like it a lot. Yes I agree overkill is good, you can be confident while running over/pushing over those logs. The details are what make it nice, they go out exactly to the fender flairs, the bends are well thought out, and I like the sunken winch area. Great job.
There has to be a fusable link somewhere between the trail and your frame. If a bumper is too sturdy impacts with boulders, the ground... other vehicles are transferred directly to your frame! If you hit something hard enough you will bend your frame before you bend that bumper. If you don't wheel hard it should be fine but if you ram something you may do a lot of damage your not expecting. Its a sharp bumper don't get me wrong i'm just giving you something to consider.
Discussion Starter · #19 ·
Yes i totaly under stand what u talking about and took that in to consideration. And ur right the frame where the bumper bolts on is a weak spot its a crumple zone. Earlier when i mentioned i was ruff, i never meant i was destructive.
1 - 20 of 43 Posts
