1 - 9 of 9 Posts
Ok so here's the story, I have a 01 sahara 5sp. I needed a new clutch disc, so while i was down there i ended up replaceing a master/slave cylinder, new clutch, pressure plate, and throwout bearing. The install went fine but after i got everything put back together i couldnt get the jeep in gear with the engine on. When the engine is off i can put in gear just fine and start it in gear and drive it in that one gear, but i cant shift out or in to another gear. Sooo i don't know what im missing...:banghead::banghead::banghead:
Any suggestions would be great!:thumb:
Did you bleed your slave cylinder? If you have air in the system it won't disengage the clutch properly and you will have problems getting it into gear.
yeah i have i replaced the master and slave cylinder about a week before i put the new clutch in. i think i found whats going on, i haven't replaced the pilot bearing yet and i tryed to spin the old one and its not budging. so now i'm looking on how to replace it.
Knows a couple things...
The pilot bearing is seated into a bronze bushing and it is in there pretty tight. I used a slide-hammer bearing puller borrowed from Autozone to get mine out. Others pack the area behind the bearing with grease and after inserting a steel rod or punch the diameter of the inner bearing shaft opening, smack it with a small sledgehammer to force the bearing out hydraulically.
I can post a pic of using the slide-hammer bearing puller to extract my pilot bearing tonight once I get home if that would be helpful.
Thanks for everyones input. I got everything fix and its shifting great. I had to replace the bearing jerry was talking about.
1 - 9 of 9 Posts
