1 - 20 of 24 Posts
I have recently purchased a 2001 Jeep Wrangler and am clueless at best! I want to start my customizing with wheels and tires but don't know where to begin. The vehicle will mainly be used for street riding with occasional light trails and beaches. I'm wanting some matte black wheels and the largest tires possible without adjusting suspension. Any advice?
31x10.5 tire...I would recommend a Goodyear Wrangler Duratrac.
Just went through the tire thing. About the best without suspension mods, as mentioned, is a 31x10.5. I learned you do NOT want a mud tire. Mud tires are designed to dig; you don't want that in sand.
I did Firestone Destination ATs. Price was excellent. Much cheaper than the others, thanks to Ford destroying their reputation more than a decade ago. Quiet, good in wet, great in sand. I couldn't be happier.
Thanks for the insight...so much I want to do but the knowledge is lacking. Will be using this forum a lot!!!
Be patient, take your time with this decision. Tires are generally more expensive than wheels and if you sink $200+ per tire for a decent 31x10.50 tire), thinking you don't need a lift, only to find a few months down the road that you wish you had a lift, you'll be sorry. Search the forum for pics of Jeeps with a less than 2" budget boost and 32x11.50 tires. I think you'll see that this makes the Jeep look "right", and the BB lift costs very little and will not change the ride.
Thx---the fun of a jeep is there are endless possibilities...that also makes it overwhelming!!
It does...if you suggest a lift I'm good with that as many already have. I don't mind putting the money in, just want to do it right and not do anything unnecessary.
You should probably decide if you'll want to lift first. Without a lift - 31" tires max as previously posted. A good suggestion:
With a lift - how much money you got? :D
You must also consider rims. Backspacing is very important unless you buy good spacers which are pricey and most of the time illegal (check your laws) and probably not a good solution anyway.
My Jeep has the stock ravine rims (want to paint black to save $ plus they're alloy not steel) which I believe the widest you can go is 10.5" without rubbing supposedly (so 32x10.5 def won't work on stock rims)
I went through the same research. I don't want to mess with my suspension either but I'm choosing (still haven't actually done it yet) to just buy coil spacers (bb) that are 2" to replace my stock isolators so I get a 1.5" lift without touching anything else (this also cost less than $100) I will be putting 31 x10.5x15 tires on mine what's nice about that other than it actually fits stock jeeps is its an easier size than 32's or 33's to find used if you're cheap like me lol
Discussion Starter · #13 ·
Not that it grows on trees, but money isn't as much the issue. I just want to do it right and get all the components (wheels, tires and lift) that are compatible.
Discussion Starter · #14 ·
If you do the spacers will you need to also get shocks?
I saw a daystar kit that brought 4 1.75" spacers and said it did not require new shocks but also had the same kit that brought some and most 2" lift kits bring shocks. That being said I would imagine spacers less than 2" and less are okay with stock shocks. (A 2" spacer is technically 1.5" if you take out the isolators that are .5") So long story short if you replace your stock isolators with 2" spacers you get 1.5" lift which should be fine without swapping anything else. (Someone correct me if I'm wrong but I'm pretty positive on this.)
Just for reference... I had the Daystar 1.75" kit with shocks and 31x10.50 tires (and 16" black soft 8s). This is how it looked:
I then put 32x11.50s on with the same lift (and silver 18" wheels). This is how it looked:
I then put a Teraflex 3" lift with the same tires and it looks like this:
I think you will be definately under-tired if you do a BB and stick with 31x10.50 tires
I kinda had the same issue since I just bought my jeep recently also. I finally decided on a 2" BDS suspension lift and 31x10.5 BF Goodrich AT's
Discussion Starter · #18 ·
That's what I'm going for, looks great!
Good deal. If you stick with 15" wheels, 32x11.50 tires are fairly inexpensive (as are the wheels).
I like my 18's, but bought them only because they were on close-out and a great deal. Didn't think about the tire price though... 18s are $$$ :facepalm:
Discussion Starter · #20 ·
What wheels and tires are you running on this...love the look!
1 - 20 of 24 Posts
