1 - 16 of 16 Posts
I am considering a lift on my 94 wrangler with a 2.5. I currently have 30x9.50 bighorn tires and would like to lift 2 to 2.5 inches and move up to a 31x10.50. What is the best kit for the money, looked a pro comp on sale would be about 575 from 4 wheel parts, all opinions will be appreciated.
Thanks,
Ashley
I have the Rough Country 4" lift with 31x10.5 tires and love the ride and look of the lift. It is the same cost as their 2" lift. ($449.00)
Take a look at the lift reviews thread on top of this page for what people like/dislike.
Jeff
What about SYE or CV driveshafts? I really don't want to change all of that right now, I was under the impression you need them for 4 inches, not for 2 or 2.5.
I heard it is a questionable gain due to amount of stress put on springs. Never worked with it myself though
When I did my install, I used the transfer case drop spacer that came with the lift. I wheel as often as I can and the Jeep gets a bit of abuse. So far, no vibes or anything to that effect. I do plan on doing a SYE in the future and removing the drop spacer at that time. The RC 4" lift is the most bang for the buck lift out there and most people that start with a 2" lift eventually go up to a 4" lift anyway. Which ever choice you make, good luck with it and post up some before and after pics.
Jeff
Thanks for the input guys, I am probably going with the RC 4 inch lift next week. How much lift did you gain with this kit, I have heard as much as 5 inchs over stock, also how do you think the 30 inch tires will look with this lift?
When I did my install, the factory springs were a bit flat and worn out. I could not fit my fist between the 31 and the fender flair. After the lift, I had a good 7" gap between the tire and fender flair.
Jeff
How well do you think the 4 cylinder will do with 32x11.50 tires? Also, those of you buying rims now, are you buying 15's for the price or going up to 16's for more tire options?
I did the 2.5 RC kit on my 95 YJ and have had nothing but issues. The kit installed easy enough, and the instructions weren't all that bad, but I vibrations ensued. The 2.5 inch kit does not come with a TC drop and RC was surprised that I had vibes given the small amount of lift. I tried to lower the TC kit using shims and grade 8 bolts, but could not get rid of the vibes completely.
So, I called JB and ordered an SYE. They were pretty convinced that all YJs need an SYE with any amount of lift, and because of the problems I had I agreed. So, I just finished installing the SYE along with a Tom Woods, (great guy, btw) custom driveshaft and things definitely got better. HOWEVER, I still have vibrations over 50 mph.
I don't think I'd have issues with a lift if the RC kit would have gone in as advertised, but knowing what I know now, I would advise anyone contemplating a lift to consider the whole package of suspension, SYE, custom driveshaft and any other item required to troubleshoot out the vibrations that one MAY encounter.
Jeff
I've had my 4" Rough Country Suspension Lift since October. LOVE IT! Pics on profile.
31's would look good. 33's would look better IMO, but I def would not go smaller than 31's.
post the item or the seller, would ya please?
that's a TJ kit. Is it still a YJ forum?
1 - 16 of 16 Posts
