I replaced oil sensor switch today since last one belched up entire 4 quarts of oil on my dirt lawn...
Lifetime warranty from O'Reilly, a $32 part.
Is it a turd?
First hour after install acted normal: fluctuating 35-50.
I hit the freeway then BAM--glued to 80 pounds and didn't leave 80 the whole day during errands, slow speed, high speeds, or idle.
Electrical problem on my end? Or lemon part?
PS--I have no more oil leak and crankcase has new oil filter and right amount of oil. Also I installed it right. The cap on the wiring harness has the pullover tab on the right side of new sensor.
Every one I have had go bad that is what they have always done peg over to the right. Sounds like inferior parts. I would suggest trying Napa or Carquest they usually carry better quality parts.
I did a quick google search, and came up with a bunch of different topics on it, and it seems lilke a common problem to leak. I think you just got a crap part
X2, but you have life time so go get a new one. However if you don't use the right socket to install it , it can be damaged put the new one in! :eek:
Back to O'Reilly's....
