Hello, I got a 31 tooth speedo gear for my jeep with 3.73 and 33" tires. I looked at all the charts and this seems correct I put it in and rotated it to the correct number. I checked it with GPS, and im still 2-3 mph off at 25mph... My problem MIGHT be that the little dot does not line exactly up if I put the clip on. The grooves where the retaining clip pull it out of alignment when I put it in. Could that be it? Thanks!
Knows a couple things...
A 31 tooth is correct for 33" tires and 3.73 gearing. You sure your GPS is set to read statute miles/mph?
also might want to measure your tires. My 33x12.50x15 Duratracs actually measured 32x11.50x15
X2
There are only a handful of tires that are actually true to what is printed on the sidewall. Typically I have seen that if it is slightly over companies will round up...similar to flat screen tv's.
Whiskey for my men...
Another thing to consider if your tire sizes are ok. The speedometer in my TJ reads 2MPH fast. It doesn't matter if I'm going 30 or 45 or 60 it always reads fast. Now if it were an incorrect gear it would be off by different amounts depending on the speed. It just always reads 2MPH fast, which is not a bad thing. If I'm in an area where the cops have an itchy ticket book I keep the speedometer right on the posted speed and I know I'm ok.
