1 - 13 of 13 Posts
okay guys, my starter went so no jeep :banghead: but i will be buying a new one very soon, any ideas on what one to buy (with a budget in mind)
If they didn't all float away by you, there is nothing wrong with having the original re-built. It was a good starter to begin with.
Okay thanks
Knows a couple things...
Yep, either have that one rebuilt by a competent automotive starter/alternator shop, or buy another OE starter. The aftermarket stuff sold by the chain stores is often little better than Chinese junk. While I might trust non-OE stuff for my Toyota that sees nothing but the street, my TJ gets way out in the boondocks where the auto club doesn't go so I make sure it only gets the good OE quality stuff.
Yup had mine rebuilt for like $50, from a local shop. Came back looking like new and has worked like a dream ever since.
Discussion Starter #6
Thanks guys, it had a POS Japanese one on it... This explains it so I'm going to auto zone to pick one up for 150
Odds are very good Autozone's will be even worse quality junk from China. I'd go OE for a critical part like that.
Mitsubishi makes the OEM starter. So, that is probably the starter that came on your Jeep.
Discussion Starter #9
Okay great advice, where should I buy an oem one from? I'm looking for something new if possible
I just replaced mine, the original 98 model Mitsubishi finally gave up, well the bearing did. Local shop wanted about $90 to rebuild, so after some looking the local oreillys part store had a reman unit, with a rewound Mitsubishi motor for $60 with lifetime warranty. I don't expect it to last 14 years, but will have to work. If mine wasn't a 5 speed that can be push/pull started, I would have went with Jerry's advice an paid the price for an OE unit.
I went with a new Remy starter for my 92. No problems so far. It was rated at 1.7 kW, IIRC. Some are rated less.
1 - 13 of 13 Posts
