1 - 20 of 37 Posts
OK.....so we all get little:D surprises now & then.
Surendipity:eek: has raised it's joyful :facepalm: smile for me yet again on my 08JK!!!
Just discovered an EASY way around that annoying door chime with the key in & radio on, when you're outside and want to have the door open for a longish period of time and the chime keeps dingingdingingdingingdingingdingin/etc
Before revealing:hide: how dumb I was to miss this for so long, I'd like to see how other forum members solved the problem.....
I think so. Shoot now I have to go test it. Hang on,
...nope, my bad. You can leave the key in the ignition and pull it out a click but the radio turns off.
Pull the fuse.
Glad to see general confusion.....heh heh heh.....
let's let this roll a bit & see if anybody REALLY comes up with what ~I~ discovered.....
Hint: SOOOOooooooo easy it was hard to believe it worked.
Hint: Remove NOTHING. Unplug NOTHING.
Interested???
Don't know if it's peculiar just to mine.....or whether anyone else has the same feature.
It would seem to me, that it HAS to be a designed-in thing.....
Farnham21 said:
Take the battery out and smash it with a hammer duh
Obviously this
KEEP IT SIMPLE SOLUTION
I would just roll down the window and keep the door closed.
SOLVE THE RIDDLE SOLUTION
If the door has to stay open I would unplug the wire harness like your removing the door. (The little red tab needs to go down.) As a side note for reinstalling, I find you want to put an extra twist in the wire. Go in the natural twist direction, to keep the wire/door-stop from sticking out and rubbing your leg.
OK Jake......I'll Bite.
Say ,did ya ever get rid of the noise in the radio or are ya just puttin up with it ?
Tha Suspense is killin me here..... "BH"
1 - 20 of 37 Posts
