1 - 20 of 33 Posts
I posted this in the wheel and tire section as well, but as more people read this than the tire I thought I would try my luck here as well.
Hey all I'm looking for some help with my new tire decision. Right now I'm just trying to get some info as all of my excess cash was put into my recent purchase of the jeep in question. Besides for some wiring for aftermarket lights and stereo, everything is stock on this jeep (as far as I can tell), no lift, stock 15 inch wheels, and P225/75/R15 tires. There are no mechanical problems, but right now the jeep looks like it's riding on tires meant for the accord I had before it. I'm looking to put something on that looks like it's meant for a jeep and will allow me to do some mild off-roading.
The problem is that I'm a complete beginner when it comes to anything like this, this is my first wrangler and first jeep. So after doing some research digging through the forums, I've found that I'm probably looking for something in the 30-32" range, but I don't know what width to look for, or if it will require spacing and how much, and is that something I will have to do on my own or will the people that mount the tires do that? Also what type of tire should I be looking at? I've heard good things about the Bfg AT's and the Goodyear Wranglers, but are they more tire than I need? Lastly someones post that I read said that they had to change the tachometer due to the increase in tire size, would this be something that I would need to do? And if so is it something that is DIY? My mech skills arent the best but my gf's dad is good with vehicals and he likes to help me out.
Any suggestions or advice would be greatly appreciated!
I have Yokohama Geolander ATS and they are pretty good tires. They handle the snow and rain very well. They are incredibly aggressive though. The tires are wearing very well, and I really think they could go 60k miles easily.
Mine are 31x10.5 and fit in there very well. I had them before my 2"BB, and they didn't seem to stuffed.
Check out treadwright tires. Not too far from you and some great deals for great tires for people on a budget and even for some that aren't.
My 285/75/16 tires were $500 total including shipping for a tire that looks and acts just like the older non kevlar version of the Goodyear MTR.
Get a 2" budget boost and you can run 32's. Try to avoid the huge body lifts, but the 1.25" is the one you should try to give the 32's a bit more room.
Good luck.
i just put on some 30 x 9.5 x 15 on i believe stock wrangler rims, but i do have about a 3 in lift. they are firestone wilderness a/t II i bought them for the MN winters hoping they do better them my 33's in the snow. ill post pics tomorrow.
also they look pretty nice with the black letters out. check out craigslist, i bought these(4) they have about 50% for 90 bucks!
"Seamed Like a Good Idea
I'm running Dick Cepick 31x10.50 on my 97 and the ran just fine before I ever added the 2.75" Suspension lift. O f course you don't have to purchese the Cepick tires but the point is 31" will run just fine with no mods.
Discussion Starter #7
Thanks for the help guys, yesterday I looked and saw that my wheels are 15x7. Will they fit a 31x10.5 or will I have to go with something not as wide? Also from what you all have been saying I've gathered that I won't have to add any spacers to fit the tire, am I right in my assumption?
Your rims will be fine, and you will not need spacer.
You might have to adjust your steering stops, but that's about it.
TJ Steering Stops
97Sahara1325 said:
That's great news. Will the change in size be small enough to not have to touch the tachometer/spedometer/odometer? Again, thank you all for your help here.
The change in tire size will probably throw your speedo off. You can get replacement speedo gears, and they are extremely easy to install.
bfg all terrains are awsome. the look good and they are not to loud or aggressive but that are an excellent tire in all conditions imo. 31 would be the biggest id go for a stock jeep. i have the bgf At 33s and i love them.
'I'm running Dick Cepick 31x10.50 on my 97 and the ran just fine before I ever added the 2.75" Suspension lift. O f course you don't have to purchese the Cepick tires but the point is 31" will run just fine with no mods.
Course you don't have to buy Dick Cepicks, ya know if you don't like tires with aggressive tread, good wear, amazing grip, and compliments all around :thumb: traction isn't for everybody ya know
I've also had a set of 31 BFG ATs. They looked like hell and drove like it too, but the wear was long-lasting. The traction was awful and I've had my fair share of slips and slides. I'll never buy another set, but there are people who swear by those tires.
Your rims will be fine and you won't need spacers. Just do the bumpstop technique mentioned. If you really care about your speedo gear (I use my cellphones GPS), the swap takes five minutes. Go underneath your Jeep. Look at your transfer case from the rear towards the front and feel for a plastic plug with a cable coming out of it. It's basically remove the bolt from that assembly pull out the unit and swap the gear then put the plug back in.
I had BFG 31s on my stock Jeep for the last few years. I only have a 4 banger though and I could really tell a difference in performance and they were loud.
They finally wore out and I just got some 235-75-15 Good Year Wrangler Radials.
I feel like my engine is thanking me. Two words.....Fifth Gear!!!!
If you don't have a 4 banger I'd go with some sort of AT 31s
i love my all terrians. i guess evryones different. i havent had them for to long so we will see another moth down the road. i like them much better than my old courser at2s.
I've had BFG A/T's on 3 different vehicles, a 72 k5 blazer in 33x12.50, an 87 suburban in 33x12.50, and currently on a 2003 Rubicon. I've not had good experience off roading with them at all. My Rubicon got stuck in wet grass, I had to lock it into 4wd just to get off the lawn. My suburban dug itself down to the axles while wheeling on the beach in North Carolina, I had to get pulled out by a 4cyl toyota pickup, that was embarassing... I don't know what BFG means when they say "All Terain" but I've had bad luck with them off road.
A 31x10.50 Goodyear MT/R with Kevlar, or BFG KM2 would be a good tire for you to cut your teeth on, they will last a good while before needing to be replaced, giving you time to upgrade your Jeep in other areas if you get bit by the off road bug.
Discussion Starter #18
Ok, I have been doing some research, and through a family member I can get a nice discount from Sears if I get the tires from them. I was looking on their website and they have a wide variety of A/T tires. I was hoping to get some opinions on the tires that interest me. Also all of the tires I'm listing come in both 30 and 31 and some come in 255 or 265 by 70 or 75.
Firestone Destination A/T
Goodyear Wrangler Slient Armor
Firestone Transforce A/T
Bridgestone Dueler A/T
Goodyear Wrangler Duratrac
General Tire Grabber A/T
Hankook Dynapro ATM.
Any opinions good and bad are appriciated here.
Thanks
Thanks
I have the Goodyear duratracs in the 33x12.50x15 size and love them. I haven't had any traction issues on the highway, wet roads, standing water, grass, gravel, 2ft of mud, aired down on the rocks at Rausch Creek, water crossing, and looking forward to see how they do in snow. They ride nice and smooth on the highway and have an aggressive look too. I think of you get them in 31x10.50x15 you'll be set.
x2 on the Goodyear Duratracs. I just put 31s on my stock 97 and they look and perform good.
1 - 20 of 33 Posts
