Just bought my first Wrangler on Friday - got new 31" Bridgestone Dueler tires today. I also found out that the spare tire holder will have to be extended so the fifth tire is sitting in the back seat for now :/
Before and after pics are attached for your viewing pleasure. Do you think I still need a lift, aesthetics-wise? I mainly got it as second vehicle for snow days and it'll probably be fine for that now, but I think my girl may need some high heels...
Also, it's been a long time since I bought a used car and I'm worrying - scrutinizing gauges, sounds, smells, etc. None of my recent cars have had oil pressure gauges and I freaked out a little at how low mine goes when I'm not accelerating. It rests at a little under 1/4 of the way when at a full stop. Does that sound normal? I'm not a "car guy" (or even a guy) so sorry if that's a dumb question.
you shouldn't NEED a lift, but itd probably look better if you get a small say 2 inch lift. id go with a suspension lift myself, but body lifts are cheap. your oil pressure should read around 40 on the gauge at rest. id change the oil and out a good additive in it before I started examining other issues.
I stacked some washers on my bottom lug on the tire carrier, it helped me clear my 33 over the bumper. Angled spare looks kinda cool too if you ask me!
Your oil pressure should be around 20 at idle. I have owned four 4.0 liter Jeeps and they all had low pressure at idle.
Well if you got a small body lift, it'd help you clear the spare tire over the rear bumper
I also hear the oil pressure sending unit notoriously gets weak, mine does that too. From what I read it is nothing to fear.
