I have a 2003 Wrangler Sahara and need new tires bad. What is the most I can do to make it look "cooler" without getting a lift? I know the biggest I can get is 31x10.5... Would spacers allow me to get bigger tires? I'm planning on getting new 15" wheels too. Probably procomp. I'm just a jeep novice and want to get the best look with the little money I have.
31's are the biggest stock. Nothing else you do will allow bigger tires unless you do a lift. But if you have a D35 rear axle you wont want to go any bigger then 31's.
Also, if you can, (in your state) get a wheel with a backspace so your tires stick out past the flares a little. Even an inch is nice and makes the jeep look " bigger" ( around a 4.5 backspace should do the trick, just check it out)
Good luck.
