Hey guys my names james I will soon be the owner of a 1989 yj with at 4.2 and a 5 speed. The jeep will be coming stock with a new frame cause the old ones shot which ill have to swap out. I have the parts for a soa, with the 2 biggest leafs from a xj added in to my spring packs and tara flex shackles, also a sye from advanced adapters with a cv rear drive shaft, ill be running no track or sway bars, a high steer set up with at pitman arm drop, building my own traction bar connected to a c8.25 in the rear open diff :/ for now and a Dana 30 front with an power trax locker, running 35/12.5/15 BFG mud terrains I know I will have to regear for those size tires I just don't know what ratio? and I will most likely need beefier axle shafts for those tires as well. I got a pretty good list of what I need so far but what els do you guys think I should add to it ?
Btw this jeep is not a DD just a play toy :thumb:
