I just bought a prebuilt Rubi, its my first jeep. It is already lifted and experiencing pretty bad bump steering. How do I measure the lift to buy the appropriate steering correction kit. I have seen on several kits they are for 3 -4.5 inch lifts. Are 3 to 4.5 normal aftermarket lift dimensions?
Mrasure from top of axle to bottom of body. Easier done at the coil spring "bucket"
But you'll have to be certain what stock measurement was. Go to any stealership with a tape measure and perform same measurement in same spot.
Here's the 2 measurements you want. The lift height is generally the average of the 2 measurements. If you get around 3" in front and 2" in rear, that is a 2.5" lift...
