1 - 12 of 12 Posts
Here is a small write up on audio upgrade. I used to do audio when I was a teenager, dare i say 20 years ago. I had absolutely no confidence in my local area car audio dealers and did not want a hack job so I ended up doing all this over the course of 4 days. Sound is infinitely better than stock, but this amp does clip when turned up to 22, you can turn the bass down to eliminate this and turn the remote gain up on the sub to compensate.
4ga battery cable into cabin
Inverter
Audio
I found some instructions on running power into the cab by removing the passenger side dash panel and poking the cable through some expandable foam. I tried this but I do not feel it is safe at all, when running the cable through the foam into the engine compartment/cowl it is surrounded by sheetmetal that can cut into insulation.
I removed the battery in an attempt to remove the battery tray to gain access to another location, removing the battery tray on a 2013 is difficult so scratch that. I discovered a hole when I removed the firewall insulation and this is the best way by far to run power into the cabin.
Battery removed
Hole discovered behind firewall insulation
Feed coat hanger into cabin to pull wire in
4awg power cable
4awg with wire loom for the stock look
Opted for a breaker instead of fuse
Audio:
I opted to stick with the factory head unit to deter theft with the roof off, but installed all new speaker wire to all locations, dynamat the enclosures and stuffed with poly fill, new amp, sub, and inverter all under the front seats.
Kicker compact sub mounted on a custom plate from member jeepedjeep
Another custom seat bracket with pure sine wave inverter, Memphis Audio amp, and fuse block.
I also ran new wire from behind the radio to the high-level input on the amp.
FYI, there is a grounding stud on the tunnel area by each seat.
Now on to the speakers, not much to be said here other than components in front and coax in rear. After installing the rear speakers I had to seal the perimeter them with silicone, made a big difference.
mounted crossover with velcro, works great.
Rear speaker bar
New wire to amp
Very nice install.
I used to install this stuff too about 20 years ago. I don't trust anyone else messing with my stuff, either. The last car I owned that I let anyone else touch was my GTR and that was only to tune it after I installed the parts :)
Definitely subscribing to this thread for when I do my install. Might try to play with a fiberglass enclosure this time.
Everything is still going strong, no issues with any components although I think it could use a bit more kick.
I have This radio: Kenwood - KDC-HD545U
and these speakers
:http://www.amazon.com/Alpine-SPS-600-speaker-2-way-coaxial/dp/B0013FMWPC
it does ok for me. I was thinking of adding the kicker power sub like u have. And put it under the front seat. Does it need to be in a tray above the floor or can it sit on the floor? I know nothing about sound systems.
I either want to amp the current set up or add the kicker power sub. Funds now will not allow both. i like the sub because it takes up little space. Dont need the earth shacking experience either. Just add some base.
opinion would I be better to just amp my current set up. It does Ok with top off
How do you get the seats out and leave the frame? I had my drive seat out but took the whole frame.
Sorry kind of scattered but not real smart on sound systems at all. I did change the speakers and head uint my self. Took a long time. But did it.
Also why run new speaker wire? Did you run new to the tweeds also?
Lastly How do you like the power sub and is it worth the money?
Thanks
Discussion Starter · #11 ·
Sorry, did not see this post.
A compact sub that fits under the seat could be mounted to the floor or on a bracket, I chose the bracket for a cleaner install.
There are 4 bolts per seat that can be removed leaving the rails in place. It is always beneficial to run new speaker wire, but not mandatory. I did run new wire to all speakers including the tweeters.
The powered sub has been worth it, but as mentioned I am removing it and going with another option.
and these speakers
Thanks
Thanks for the feed back. Still making up my mind. No one around here stocks any of the under the seat subwoofers except best buy Kicker. I would like the hear one before buying but not in the cards.
1 - 12 of 12 Posts
