YesIve acquired a fully stock 2013 2dr sport. Im stoked to start modding her out and get her on the trails, only problem is where to start. I have a ton of questions but I guess the main ones would be,
Can 35s run on a 2.5 lift?
Do i need to get the shocks and speed bumps with the lift?
Do i have to regear on 35s?
With the lift and the tires, do i need any extras like stabilizers, ect.
And finally, could I do this myself?
Yes to shocks and BUMP stops not speed bumps
You should
C gussets and some type of axle reinforcement especially the front (sleeve, truss). Add exhaust crossover.
If you are mechanically inclined, probably everything but gears and gusset/axle reinforcement (unless you can weld).
