1 - 19 of 19 Posts
Just picked up my 17 Rubincon recon and looking to lift it. I will be using it a s a daily commute car. Would like to run 35s tires and wanted input on which lift kit and whether or not i so should go with a 2.5 or 4 inch lift since that's all Jeep has available that would be warranted.
Thank you all for your input and look forward to learning as much as possible form this site
The Mopar 2 inch is all you need to run 35s. The 4 inch is overkill. Stick around here, read all you can. Tons of great info here.
Sent from my SM-G935P using Tapatalk
newbie
Thank you. Would you say i will still get the aggressive look with a 2.5 inch lift which i think mopar as per jeep is 2 inches. Also what tires and rims would you recommend i know the rims are a matter of preference but i am thinking 18s at least
That's all a matter of choice. I'll be going with Nitto Ridge Grapplers on a 17 inch wheel for mine. Lots more choices and better prices in the 17 inch size.
Look at the different threads​ on here. Lots of great pictures of lifts and tires. To me, the combination of the 2 inch lift and 35s are the best look for the JK
i know i will be crucified for this question but would the 2.5 or 4 inch lift effect my mpgs. looking through the threads but havent seen anything with the 4 inch or 2inch mopar lifts
:atomic:
Anything you do in the way of a lift and larger wheels and tires will lower your mileage. More weight & less aerodynamic.
Discussion Starter #7
figured as much but worth a shot. will just go with the 35s and 2.5 inch lift. don't want any issues in the future since it will be my daily car
Sent from my SM-G935V using Tapatalk
newbie
2017 JKUR HR with Mopar 2", 17x9 wheels and 35x12.50 Nitto Ridge Grapplers. Very happy.
Discussion Starter #10
SO i get to jeep to pick up my jeep which i put a deposit on last week and they tell me the dealership which they did a swap with sold the vehicle and i need to factory order it. I am like wtf u kidding me so now they are telling me i have to factory build it from scratch which takes 6-8 weeks. I am at my wits end now and to make matters worse they aren't even compensating me for their mistake. Unless u count minus 1500 from msrp your idea of doing the right thing.
Around here you can get 8% off MSRP without any problem... At least $3500 and sometimes $4000.
Reactions: Rocco9954
Bump. I just got a 2017 JKU Rubicon. I was wondering how much in height did the 2" lift and 35" tires actually add to your rig?
I literally only have a 4.5" in extra clearance for my garage door :blackeye
Most lifts take the weight of accessories (winch, jack, etc) into account when figuring their height, so if you don't have those heavy accessories or add-ons, you'll often get more than the advertised height. You could get as much as 3-3 1/2 inches from some 2 inch lifts. And then figure in another 1-1 1/2 inches from the increase in tire size.
Basically, you may have an inch or so to spare or you won't make it, lol.
I agree with the post above. I have read somewhere on the forums that the Recon has a small lift over the stock sport wranglers. If that’s the case then you might only get 2” from where you currently are. I would try to find the forum on someone lifting a Recon to confirm. I netted about 3” with the lift before adding the winch. I’m guessing a 1” -11/2” on tires. My stock tires were basically 32s.
It seems you may have some legal options here. If a price was agreed upon and money was accepted, that sounds like a contractual agreement was established to me. I would look into this some more.
1 - 19 of 19 Posts
