I have a NIB TeraFlex HD Tie Rod & Drag Link Kit. It is the bottom mount, 1.25" forged drag link and 1.6" 4140 chromoly tie rod. I was planning to run it with a CT3/Falcon 3.3 shock setup (also available separate or as a package with this), but I decided to go taller and bigger.
https://teraflex.com/shop_items/54d565388ca57b6ef9ef9980
Specs:
The TeraFlex HD Tie Rod & Drag Link Kit is designed for extreme conditions that typically cause factory steering components to bend and fail. HD Tie Rod Features: • HD 1.6” O.D. 4140 heat treated chromoly • Over 200% stronger than factory tie rod • Forged tie rod end housing designed specifically for JKs • Allows proper clearance for use with factory 17” wheels • Tie rod end joint incorporates same features found in TeraFlex ball joints, including 4140 chromoly ball/stud and 1045 carbon steel housing • Also features adjustable preload tension to ensure proper long term durability • Includes the clamp #1123160, or the TeraFlex Steering Stabilizer Relocation Kit The joint is pressed into the rod end housing and secured with a snap ring. When oriented in the Tie Rod configuration, the joint offers a total of 14 degrees movement to minimize tie rod roll, but will still allow maximum turning. HD Drag Link Features: • 1.25” O.D. fully forged drag link eliminates excess movement during hard steering maneuvers • Utilizes oversized DOM factory style adjusting collar and pinch clamp for simple adjustments • Tie rod end joint incorporates same features found in TeraFlex ball joints, including 4140 chrome moly ball/stud and 1045 carbon steel housing • Adjustable preload tension to ensures proper long term durability • Joint is pressed into rod end housing and secured with snap ring • Fits OEM 17" wheel
Retail $789.99, everyone selling it online for $750. $650 shipped.
