I've done a lot of lurking trying to find a solution to my Jeep's vent problem, but none worked??
2004 - Wrangler w/ 4.0, A/C and no Cruise.
Problem - Air will not come out the front vents, it will just come out the floor. Defrost and Floors work fine. A/C blows cold and works fine, it just all comes out the floor.
Attempted Fixes - I've heard it could be a leaky vacuum hose. I followed the hose in the motor compartment and didn't find any leaks. I disconnected the hose from the box located below the battery when the Jeep was off and heard air release....so I'm assuming it's not a vacuum hose leak. I also check the arm that controls the blend below the dash and it looks fine.
Suggestion? Any help to a newby would be greatly appreciated!
