Read Only
So I replaced the radio.. I pulled out an aftermarket radio and used the same harness.. I also swapped out the front speakers (since 1 was dead).. I could not get my hands up behind.. I pulled the dash out a little to get in there.. And since doing the I don't have any turn signals, brake lights, hazard lights or horn..
The wipers, head lights, and running lights are all fine..
:facepalm:
Read Only
WE checked the fuse block.. both under the hood as well as under the dash.. everything is getting power.. no blown fuses..
the mechanic found one of the wiring harnesses from the steering column was broke/disconnected from when I moved the dash out.I'm thinking the plastic clip to hold the harness in place was broke and moving the dash out was just enough to disconnect it...
Live and learn..
