Hey guys,
Looking for some help here. I am super close to completing this 6.0 swap into my 2000 TJ. Trouble is now I have it all running and driving but I am getting a no bus message in the instrument cluster.
I trimmed everything but Coolant temp and oil pressure sensors from the engine side.
I'm wondering if maybe I clipped something I shouldn't have or if I should be looking elsewhere. I had zero "no bus" issues before the swap.
Thanks,
Chris
Sounds like you are trying to use the jeep cluster w a gm engine
I don't see that happening...
The 2000 tj uses a CCD twisted pair bus
The data for the cluster gauges comes from the pcm
The sensor outputs goto the pcm then the pcm encodes it on the CCD bus and sends it to the cluster
CCD data also goes to the air bag controller and the skim module if you have skim
Unless you have the tj pcm connected the cluster will not function and if 1999 or 2000 or an xj 2001 CCD bus cluster the odometer will say no bus
Hey guys,
Thanks,
Chris
Hello Chris.
I am having the same problem after a ls1 swap. I have checked the powe at the black pcm plug also ground and the data like voltage is there. But still have a no bus issue. Have figured your problem out. If so you maybe able to help me.
Thank you for any help.
Retired Moderator
Hello Chris.
HAPPY THANKSGIVING!!!!!!!
