1 - 12 of 12 Posts
The title says it all. I'm putting in one of the tuffy or rugged ridge stereo consoles in the next few weeks and want to move my stereo into it from the dash (so I can use the dash spot for my light controls). My Jeep has no carpet, just the floor with a bedliner coating all over it.
How would you suggest running the wires to the stereo? Split loom tubing and screw it down by the shifters? run it to the passenger or driver doorway and under?
Wiring costs aren't an issue. Just want it to look decent, hold up against an always exposed cabin and be relatively easy to do.
Thanks!
Denis
You could go out the firewall and back in through the floor with proper grommets, but I would just go under the door sill and then under the seat.
Sandy - I'm thinking you're right about the door sill. I was thinking of taking it out the passenger side and just zip tying some split loom along the doorway, tucked under.
Retired Moderator
That would make the most sense. There are other wires running along that area if I remember correctly. Might be just my sound bar/light wiring......
Yeah, but if you go passenger side, make sure you don't route it in the way of the slides or pivot.
Put the carpet back in? :thumb::dance::whistling::D
You might be able to run the wires through the floor against the back of the firewall inside, then underneath the Jeep inside of some tough wire looms or a sealed tube, then back into the center console.
I wired in an aftermarket soundbar into my wrangler, ran the wires under the passenger side door sill lip. Also have train horns mounted on my YJ's hood with compressor in the back behind rear seat. 5/8" hose ran under driver side door sill just fine with wire to compressor on passenger side, you can't even see it except for where it is zip tied to the roll bar.
I would use a wire loom just to keep them in check......looks way more professional, as well....
Discussion Starter · #12 ·
I like the idea of the heat shrink tubing as well. Once I get everything ran for both the lights and the stereo, I'll heat shrink the whole mess.
1 - 12 of 12 Posts
