I was driving the day before last and when i went to leave where i was it was dark out and i didnt have any dash lights. I have my brake lights and head lights, just no dash lights, my little shift light an turn signal lights an e-brake an 4x4 lights work just none of the gauges. any ideas?
turn the dimmer switch back up:D
probably just a fuse.
lol i checked the dimmer switch, actually my dimmer switch had an issue where it would only be on in a center position and now they dont come on at all, which fuse would it be? up under the dash correct?
I am having the same problem on my O4 unlimited. Did you fix it? I tried replacing the headlight switch and that did not work.
Had this same problem, my dash lights would come on and off in my '94. I thought my parking brake may have severed a wire and was shorting out. Finally I started playing around with the fuses and the panel fuse seemed loose and kind of dirty. I took it out and cleaned it with my spit a little and stuck'er back in. Hasn't done it since...
My Tac light is out and its kind of a pain in the arse any ideas on how to fix it without tearing it all the way apart seeing as its cold as hell here now?
