No headlights, but everything else works.
3434 Views 4 Replies 5 Participants Last post by  Luckymac
Hey Guys. I am having headlight issues with my 87 Yj. Everything worked fine. Driving home form church they flickered and then went out. Parking lights, tail lights and brake lights all work fine. I replaced the switch today and still same problem. Not sure where to go next? Just picked this up as a project I have wanted to do for 10 years. Any help would be great. I tried to check the 2 relay's under the dash but wasn't sure where the wires came from went to.
In the few weeks since you posted this, did you happen to find the problem? Driving home one night my yj that I bought three days earlier lost its headlights as well but the panel lights, dome lights, parking lights, and sidelights all still work. Is it really the switch problem? Or wouldn't that cause all the lights to malfunction?
Check grounds behind headlight buckets, check fuses, was the switch getting hot when they were functioning?
· Super Moderator
The headlamp switch on YJs is weak. There have been many, many posts about this.
My best suggestion is replace the switch and find a headlamp relay conversion. Search the net or this forum for headlamp relay.
You can disassemble the headlamp switch and clean the contacts and try to clean up the bi-metal circuit breaker if you like to fiddle around. If you are more practical than a tinkerer then just buy a new switch. I think they are under $30.00.
The real key to prolonged headlamp function is to install a headlamp relay conversion. It rerouts the elictricity directly to the headlamps from the battery, rather than through the switch and then on to the headlamps.
Very important is to insure good grounds at the grill panel. I picked up a measured additional 10% in headlamp voltage simply by disconnecting the grounds at the grill panel and scrapeing away the paint and cleaning the terminals, then reattaching the grounds with a new screw and dielectric grease.
Good Luck, L.M.
