2011 JK Rubicon, I have no dome lights come on either with the doors open or the multi function switch. Note they work manually when you push the light switch on the roof. Fuses have been checked, door plugs have also been checked for corrosion.Anyone ever figure this problem out? I have seen many people post but no actual fix that I found.
Does your radio turn off immediately when you open your doors after turning off the key?
