1 - 15 of 15 Posts
newbie here. was wondering what kind of problems or what can I expect
if I want to go offroad and do a little 4 wheelin without any lift? I am
not planning to lift my jeep as I will usually just use it to tow behind my
motorhome.
I am not planning on going into real rough territory just off road to explore
some different roads and sights. nothing major or extreme. is there
anything I have to do to my jeep to prepare for just a little light off road
excursion? thanks for any suggestions and help. luv my jeep.
:iamhappy::iamhappy:
The only practical reason to do a lift is to fit bigger tires in there for more ground clearance.
As long as you don't start dragging bottom you won't have any problems at all, assuming the proper tire tread for the surface you're trying to conquer.
I've wheeled my stock Sahara several times. You will become a much better off road driver as you need to pick your lines more carefully when you are stock. The jeep is usually more capable than the driver. The best free modification you can make when going off road is airing down. Otherwise be smart, stay out of water unless someone goes first or you know for sure how deep it is and what the bottom is like and don't wheel alone. Have recovery gear and a first aid kit on board and an air compressor so you can air back up.
Many days I wish I'd either not lifted mine, or at least went with a simpler lift especially now that I'm not planning on crawling big rocks after all. I still would have probably needed to do something eventually because armor would have still weighed me down, but I also had some of the stiffest springs from the factory stock due to the 4 doors and the tow package (I assume at least or just got "lucky"). They're definitely plenty capable stock. Like AZrat said the only reason to actually lift is larger tires. I did that 4 years ago and only just last month finally got new larger tires (lack of $$ and other mods first). Along the way I started considering some of the new tires/sizes that might not even need a lift either. Sounds like for your purposes there's probably no need for a lift. If you change your mind down the road and need to build the Jeep up a bit you could always swap to trailering it behind your RV instead of towing it.
Nicely stated. On top of that, there are even some slightly larger tires that you can install without a lift... The 255/80-17 is quite popular on non lifted Jeeps.
Reactions: Minion Wrangler
I have a stock height jku. For your average forest road type stuff you shouldn't have too many if any problems. I recently started wheeling with a group and attempting some of the more difficult trail systems in my area, and being stock my skids definitely get more of a workout than the lifted rigs. A lot of times I've noticed that if an obstacle looks difficult, I can take my time and pick a line where I don't scrape or can minimize it, but things like easy looking humps in the trail that are just a quick up and over for a lifted 4 door or even a stock 2 door I end up scraping or even getting hung up on because of my poor breakover angle. While tapping the skids on these humps doesn't hurt the jeep much, scraping all day on what should be the easy stuff does make a day of wheeling tiresome and less enjoyable. Originally I had no plans to lift my Jeep, and for the type of wheeling it sounds like you're planning I probably still wouldn't see a need, but I decided to order a lift to improve my breakover angle. Still, even with the scraping issues a jeep on the stock suspension is pretty capable:
https://m.youtube.com/watch?v=fx-8bn4Xyvs
motorhome.
Your approach to a Jeep is the same a mine, I ordered the Willys Edition with 3.73 gears and Posi-Loc rear, plus the Willys comes with the same tires and wheels as the Rubicon does. I couldn't see buying the Rubicon just to ride dirt roads, not interested in riding over anything bigger then "Baby Heads", that's a dirt bikers term for rocks about the size of a baby head, you get the idea. My jeep will be pretty much stock from the factory, that's the way I want it.
trainman
Need is a key word here...If you only plan to do minor offroading with little challenges, then I agree the stock JK is very capable. If you plan on doing more with more advanced challenges, then a lift may be beneficial.
Keep in mind, many just get a lift with bigger tires for the look and rarely off road..It does make the jeep look cool.
Good luck with your adventures.
A few weeks ago, I drove to Crown King via Lake Pleasant. Arizona folks know the road. My Jeep is stock, a '16 Willys with manual transmission. That was doable only by getting winched off a particularly nasty ledge near the finish at Crown King. Should have stacked more rocks. My skid plates took a beating, but they're still there, if a bit bashed in.
The friend who winched me has a '16 Rubicon with a Mopar lift and other nice goodies.
People here in Arizona think that's a moderate trail.
There's so much of Arizona that's...moderate.
I was never going to lift it...uh...
I'm going to lift it, and eventually get an ARB rear locker and a gear swap to 4.56.
Then I'll probably break the front axle and differential. So by then, I'll have enough $ for a D44 front and a locker up there, too;)
For a stock Jeep, that was about as much trail as I'd want to do. One could do even more, probably, but tolerance for damage would have to be pretty high.
I didn't air down for fear of losing clearance, and I don't have sway bar disconnects. That'll be part of the lift.
Never felt that I needed lockers, though undoubtedly they help in some places; getting hung up was all about break-over angle. Had nothing to do with locking differentials, although they would have come in handy.
And now that I'm kind of liking getting out and about with my Jeep, which still has less than 10K miles after almost 2 years, I wonder if getting a new Rubicon and lifting THAT wouldn't be just the ticket...
This is like motorcycles...where does the silly buying end?
Using common sense, I've gone off roading in my stock jeep numerous times with no issue. Just stay away from big rocks and mud if you're stock.
one other question my jeep is a 2 door wrangler. do I need to add any additional
skidplates?? thanks
If you're not doing anything really serious, I'd get an oil/trans skid (the one hole left in the factory skids) and maybe think about the diff covers if you end up hitting them and call it done unless you start doing anything more serious.
The factory skids for the TC, gas tank, and evap cannister should be good for light stuff. I've done some moderate stuff a few times in my Jeep (Slickrock Road in CA, and a few parts of the High Lakes trails) and the worst wear has been a few small dents in the gas tank skid and some good bashing of the factory transmission crossmember from high centering on granite slabs a couple times. The TC skid has a lot of scrapes in it but no actual dents.
I don't think I've come anywhere close to hitting the transmission or oil pan but just because it's unprotected it's really high on my list and is my next mod. Unfortunately I keep having maintenance $$$ get in the way this year and keep having to put it off. I'm up to hard top seals, ball joints, drag link, and a full alignment so far so my mod money is shot.
1 - 15 of 15 Posts
