1 - 12 of 12 Posts
ive trouble shot my jeep at first i thought it was the fuel pump/ regulator bc it wouldnt start but then after it was towed to the repair shop it started right up,,, Well it wont start again, and i checked the power to the fuel pump and i get power when they key is at the ON position, but when i crank it over to start the power doesnt reach the fuel pump, ive checked the relays im completely lost on what to trouble shoot next,,, does anyone have any suggestions or ideas they would be much appreciated
I have a 99 Wrangler 4.0 put a new fuel pump and regulator in yesterday, still won't start. Checked the relay under the hood you can hear and feel it click; went back to the tank and unplugged the plug, getting power at the plug at the gas tank when the key is on; when I turn the key further to engage to start engine, I lose the power.
Knows a couple things...
The ASD relay provides power to the fuel pump relay and the ASD relay will not stay energized unless the ECM (engine computer) is happy with everything like from the crankshaft position sensor.
To me, your fuel pump problem sounds like the ECM is not happy, check your sensors.
Should I check my crankshaft position sensor and is there any other sensors that should be checked as well?
Well........just replaced crankshaft sensor and it's a no go! Getting ready to call mechanic w/tow truck, any other suggestion would be appreciated, thanks in advace.
Before I called a tow truck, I would jumper the fuel pump relay.
Can you hear the pump actually running?
What we ended up doing is running an external ground from the fuel pump harness to the chassis and the guy that did it believes that my computer is on it's way out; is there any way to check computers or is it just an automatic replace?
THANKS EVERYONE FOR YOUR HELP!
well what controlls the ground to the fuel pump does anyone have any ideas so i can fix it for the long haul instead of a quick fix??
im having the same issue with my 99 sahara. it wont turn over and the computer is saying no bus bu5. what did you have done to get it started. was it an electrical shortage?
1 - 12 of 12 Posts
