Hi guys. I'm new here. I have a 99 2.5l manual and I'm having a spark issue. I have replaced the crank sensor, cam sensor, coil, plugs, cap, and rotor. still no spark. I used a test light and there is power going to the coil but no spark coming from it. Jeep will crank and crank. It is getting fuel. Fuel pump kicks on. ASD relay is good. I'm lost!
The ground is good and I'm testing for spark by taking the wire off and using a spark plug against the block
