jeep has no window fluid. when i pull the lever there is no sound. is there a fuse or something i should try or should i assume the pump has kicked the bucket.....
options and how to on how to replace?
Can I assume you do have fluid (with antifreeze) in the reservoir? If it was straight water, depending on your local temps it could just be frozen.
The pump is located in the reservoir at the bottom so it would be easy to get to in order to check the wiring. The pump itself is about $25 so if you choose you can replace it and hope that it isn't the switch in the column which is a bit trickier!
lol ya there was liquid in it.... im thinkin new pump and if it doesent work then hard wire the new pump to a push button and call it a day lol i just really hate electrical work
