hi everyone. im having a few issues and im not sure whats wrong. ive been having some loud noises going on in my front end. for a while I thought it was my right front axle U joint, but I just replaced it yesterday and its still making the noise. and also my rear sway bar bolt is loose. the noise is a severe clunking sound. also, when im going about 50 MPH, my jeep starts to shake really bad. its only when im going 50. if its above or below, its fine.
You need to check all of your steering components and suspension as well. Check to see if there is any play in anything. Drive shafts, hubs. Everything.
Have someone move the steering wheel to right. Look for some slop in yourtie rods and drag link. It sounds like your track bar is loose or the bushings are bad.
Loose bolt on the skid plate causes vibration like that? Been chasing a high speed vibe for months, I'm on it.
