89 YJ 2. 5" lift 6 cylinder 5 Speed.
I have owned this jeep for 10 years. It has developed a loud groan/ creak when i turn on uneven surfaces.Seems to be in the vicinity of the rear springs. It is worse when I back up and turn onto an incline. Sounds to me like a very dry bushing but I have done the following with no luck in getting rid of the issue:
*Changed the spring bushings and bolts. Greased em up with silicone grease
*Cleaned and greased the shackles.
*Removed, greased and reinstalled the large sway bar over the rear end.
Still makes the same loud, dry groan / creak. Only when turning onto a an uphill surface. I am thinking that it is not the springs because they make no noise when I bounce the vehicle and I get no noise when traveling on a straight bumpy road. My next step will be to change the springs but hate to do it if that is not the cause.
Any suggestions? This is making me crazy.
thanks,
Greg
thanks,
Greg
