1 - 12 of 12 Posts
Did a search and could'nt find the answer. Is it wise to disconnect the air bag when hitting the trails - bogs - rocks - etc?..... Learned the hard way to remove the trailor hitch ahead of time.....:D
Retired Moderator
No, there's really no reason to. If I have a passenger I might disengage my passenger air bag some times, but otherwise the jeep has a different type of air bag release mechanism. Most cars are in the bumpers with sensors. Jeeps have a type of inertia switch under the utility box. I've NEVER seen an air bag go off wheelin. Not even in a flop.
If you have an incident so severe offroad, you'd probably WANT the airbag to go off. Leave it on.
I flopped my TJ last August and it didn't go off. I ran into a tree at about 7mph and the airbag didn't go off.
I do believe that the TJ's airbag sensor takes into account speed, and I doubt the speeds obtained offroad (for MOST people) would be high enough to trigger the airbag in the event of a collision.
Retired Moderator
i have no idea.. Thats why i'm wondering how do you turn airbags off
What you are looking at down by your shifter is the passenger side air bag shut off. You just use your ignition key and when the light is lit then it's disengaged. Only way I know how to disengage the drivers side is to pull the fuses or take it out. However I still wouldn't suggest it. I've never seen one go off from wheeling.
1 - 12 of 12 Posts
