check engine light is on, code 33.
I put a new relay in the box under the hood where it says the ac is. Drove for about 4 miles and check engine light came on again with the same symptoms.
Dose anyone have any ideas with a fix.
This is my daily driver and i need help so i can stop doing this >:banghead:
It could be the wiring or a connector between the Fuse box and the AC unit, a Code #33 is a open or SHORTED condition in the AC Clutch Relay circuit.
do you have a/c?
No ac
I checked the codes by turning the key off and on and found that there were more codes
33 35 i think
you might continue to get the 33 code. the system is considering "having no a/c" as a fault. try disconnecting the battery for 15 minutes and check to see if 33 goes away. there is no 35. you may be getting 55 foe test end.
