Yes.. another one.
I understand how to mount my off road lights to my light bar.
I understand how to run the wiring nice and cleanly to the battery.
I understand how to run the wiring from the switches to the relays and how to mount the switches.
Here is where I am getting lost.
How do I run the wires thru the firewall?
There HAS to be holes somewhere but, for the life of me, I can't find them.
Oh.. 2010 JK sport.
The Bad Guy
There is a much easier location. Pop the side panel of the dash off. A flat head screwdriver works well. You will see a nickel sized hole filled with foam. Run the wire through there with a coat hanger.
Discussion Starter #6
I tried that.
I didn't mention that I am also running a CB antenna cable.
The connector is too thick to run in that little hole so, I will look around the brake pedal.
