Linkage is different but you change or modify the original one and make it work. (I have one if you need one) Novak makes a great cable shifter.
4wd dash light won't work
My wiring worked for the speedo ( I have on 05)
Different driveshaft to bolt to the balancer or swap out the balancer to accept a SYE.
Different u joint sizes for the front driveshaft (can't remember if it's 1330 or 1310)
The difference in crawling is amazing!!!
