1 - 12 of 12 Posts
I will update during this build process. I am putting in a 1974 Ford np435 backed by a 1973 t style ford Dana 20. It is coming along right now.
Righteous combo! Are you going to be re-drilling a CJ bell housing to connect? You also might have to get the hesco harmonic balancer crankshaft position sensor kit.
I plan on really diving into this over the weekend. All of the clutch parts, slave cylinder, master cylinder etc are to be delivered. I already received the advanced adapters pilot bushing. I am really excited to see how easy this goes together. I don't know how much lengthening/shortening the driveshafts will need. I will also have to weld up a substantial tranny mount based on the ford bronco style mount.
Will a CJ clutch pedal setup bolt right in or will you have to make adaptions?
Good Luck, L.M.
Discussion Starter #7
I will be using the stock yj pedal set up. I got a Cj clutch master cylinder. I will make any necessary mods if necessary. I will know more when I pull the stock drivetrain.
Discussion Starter #8
Rear and front drive shaft out. Shifters out. Clutch controls out. Unfortunately my floor jack has no way of reaching the tranny. Thank god I have an engine hoist. Looks like the drivers side door is coming off so the boom can go in. Tomorrow, it all comes out.
Let the air out of the tires and your jack will prolly reach....
I used to do that all the time 25 yrs ago w my sky high chevy's
1 - 12 of 12 Posts
