I have a 97 TJ. Got a set of nerf bars to attach, however, the "channels" under the body, (appear welded to bottom of tub) where they bolt on are rusted and need replaced. Can anyone assist me in the identification of these parts as well as a location to obtain them ? I was also told that I could get Nurf bars that attach to the control arms.
Thoughts any one?
If you're talking about the kind of nerf bars I have (and have installed elsewhere), you should be able to just remove the two big bolts going into the frame, replace with nice grade 8 stuff and put them back on. Whole job should take you 30 minutes unless you have to grind/drill the existing bolts.
