hi Guys
I bought all 3 of these items from amazon...to compare. FYI: you need 18 inches to match the stock jeep 4.0 metal fan. probably go to 19" or 20"...but non exist that I found
-Allstar Performance ALL30095 18" 6-Blade Molded Nylon Fan $33
-Flex-a-lite 418 Black Nylon 18 3/8" Belt Driven Fan $26
-Maradyne MFA118 Texas Twister Series 18" Fan $25
so far Flex-a-lite and Allstar are exactly the same. not a single difference
Will be getting Maradyne tomorrow...will update this post
hope this helps anyone trying to get most air flow with nylon fan
some modifications you have to do:
1 - cut a hole out of the center of the fan.
a - used a paint pen to mark and cut the main whole to fit over
the clutch back. (and drill to start the circle)
b - use a little paint to outline the holes where the bolts will go in
2 use small 1/4" deep spacer to keep fan from touching the clutch... not critical but probably will make air flow better and look cleaner.
