Question for the group. It seems like 90% of the time I offroad I throw a O2 sensor issue within24 hours. Generally it goes away..once I had to replace the sensor. Went wheeling yesterday and today I have a P2096 code to deal with.
I wheel at Rausch creek most of the time in PA. Hard rock and bumper deep water holes mainly.
Any ideas? It's a 2012 JKU. I'm starting to get annoyed ;-)
dirt road inspector
P2096 - Downstream Fuel Trim System 1 Lean
I had this code:
P2099 - Downstream Fuel Trim System 2 Rich
The dealership shop said it was from an exhaust leak on the passenger side in front of the cat converter. I think it is a way for my Jeep to sit at the shop for two days and me pay $200 for the privilege.
Yeah... That's what I'm afraid of
Well the mil light went off on its own this morning. Hummmm
if the light went off by itself (should take 3 good start cycles to clear) then the PCM doesn't detect the error conditions that tripped it.
possible causes of this code
could be exhaust leak (or cat issue - clogged/wet?)
02 sensor issue (probably not since only occurs after going wheeling)
wiring issue with 02 sensor (probably not unless water issue)
bad fuel (contamination - fill up at same spot station normally don't use)
