Hey guys, new to the forum.
Background - i bought a 2007 jeep wrangler X. It had low miles but was a rental at one point through its life in alaska. Its in working order except a few things which i have been unable to revive on the JK.
My obd2 will not get power.
I have checked the m3, and replaced any fuse i thought could be the issue (fuse J14 was bad, and i did not have a fuse in M30, which i recently added ). Ive lifted up the fuse box and checked the harneses and couldent get it to get power (using a volt meter) by wiggling it. Ive tried the three times off and on quick and it does not show any codes. I also did not have a fuse on I get about 6 volts on each of the power outlets.
I do see three lights on my dash though, which at first would kick on every so often then go away after a restart. now though they are on 24\7 with the ABS,ESP\BAS, and Looks like traction control (car with swervs behind it, like my wife is driving....)
Ive made sure the connectors are jacked in sturdy to the back of the OBD2 sensor... but im at a loss... Any ideas guys, i really dont want to take it to the stealership.
