I have a 00' Sahara. There's been an odd noise under the dash. It sounds like its coming from under the center area. It sounds like a plastic ball bouncing in a plastic cylinder. Only happens over bumpy roads. I'm assuming it has something to do with the hvac sytem but not sure. Any ideas would be appreciated.
I had the same symptom you describe. Sounded like it was from inside the dash, steering column area.
Next time you anticipate hearing that noise grab your 4WD shifter, force it downward hard and hold it. See if that stops the noise. The rubber bushing that keeps your shifter arm from knocking on the body can wear out.
