Hi all,
Does the oe clutch have a break-in period and how many miles if so?
Is there a problem with it in reverse up hill or pulling something on winch?
Does it tend to slip and smoke easy undertow?
Just drive it like normal. No need to break it in.
Reversing up hill is hard in the JK because reverse gear is insanely tall. I avoid reversing uphill if possible.
Use the winch to pull, not your drivetrain. If you're pulling something out, do it in first not reverse. Gears are stronger in forward motion.
You shouldn't be slipping at all. If it's slipping, you need a new clutch.
