1 - 20 of 22 Posts
I'm looking at a couple bumpers for my JK, front and rear. I know a lot of people say it's not good to fit a front bumper with a winch to a stock suspension JK. But what about just the bumper and off-road lights? Would two basic style bumpers [no stingers or overly large hoops on the front, no swing-arm tire carriers on the back] be enough to overload the stock suspension of a 2-door?
Never heard you shouldn't put a winch on a stock JK suspension. New one on me
The Bad Guy
These weren't guys in a ski resort parking lot telling you this was it?:D
That said, lol. Not sure who told you that but it is absolutely not true. You can put what ever bumper on a stock suspension with absolutely no problem, that includes hoops, winches, jacks, shovels, or what ever else. If the stock suspension was that weak not to handle a winch then it wouldn't be worth off-roading but it isn't.
that being said, if you're concerned about weight you could get an aluminum off road bumper, and a lightweight winch with synthetic rope, probably save 100lbs..
You actually have to do front and rear at the same time. Learn from my mistakes. I only did the front bumper with a winch and the first time I backed it out of the driveway it felt wrong. When I hit the bump at the end of the driveway I rolled the jeep end over end because all the preload on the front suspension. True story.............
your bumper didn't cause the end over end...and if you were backing up the 'preload' on the front end wouldn't make it roll backwards like a turtle...something else was going on there! Is your driveway almost vertical?
You can replace bumpers singlely or as a pair...any way you want. Or take one off and go nekkid...doesn't affect anything. If adding a new bumper and a winch drops your front (or rear for rear bumper) more than an inch-then your SUSPENSION is too weak and due for replacement. To test it...just measure the height from ground to bottom of bumper-then stand on the bumper and have it measured again. YOUR weight is going to be MORE than a new STEEL box bumper and a winch...unless you are a skinny little guy...
I was there man.
Was this a full steel bumper with winch on one of those battery-powered Jeeps that a 3 year old can drive up and down the sidewalk in? :rofl:
:cool: I use a mobile winch, that I can takeit/or leaveit-
My JKU has the towing option and I've got a pair of Olympic "rock" bumpers
No weight problems/ no spring problems/ no wiring problems/ nobody see's it problem-
:rofl::rofl: JIMBO
Nope, full size jeep. I even got airborne.
:rofl::rofl: JIMBO
Is that a "rock roller" on your front? What do you use for a mobile winch? Is it one of them wheel winches ot just a hi-lift?
op. a heavy bumper and winch may cause a little sag in front but thats all, its not a problem at all.. i have a pretty heavy bumper and a heavy winch and im stock no probs at all
:cool: Nope, thats a "race" auto tranny cooler-frame mount-
I use a Warn 3000 lb winch, but I have a HILift and a 3000lb comealong, with multiple snatch blocks for heavy load!!
:rofl::rofl: JIMBO
:rofl::rofl: JIMBO
Ok. I couldn't make it out in the pic. I know your running a cooler but I also know you have some tricks up your sleeve.
That is a hell of a recovery setup. I'm glad you bring the extra gear. You ever use the 3k for extraction? If so I want pictures. That is one big atv you got there brother.
:D Heh Heh, Actually I have two aux coolers, kinda redundant and overcautious-maybe !!
I have two 2" hitchs on the jeep, and two 2" hitchs on my trailer, I've used the winch on the back of the trailer -
Once at Gold lake, the jeep got over the rocks, but the trailer got off-kilter on the rock and I used the winch, on the assend to-"persuade" it off !
I haven't used it to get "unstuck", I haven't been stuck for a long time-
:rofl::rofl: JIMBO
:rofl::rofl: JIMBO
Never too cautious with cooling where you go.
I like the winch carriers that can mount on a front or rear hitch but my winch is just too damn heavy to be doing that with so I just carry an extra jeep. Haha
Avoiding getting stuck in the first place is key. Since I acquired all of my recovery gear I have not been stuck. Go figure.
:cool: Yea, remember, someone said that if you don't get stuck--you just ain't trying hard enough !!
Thats as smart as saying, that if you don't run out of gas, you just aren't driving far enough !
Amazing what WON'T happen, if you "Drive smartly-on road/off-road"
:rofl::rofl: JIMBO
Bumpers and winch made my stock suspension wallow like an ailing wildebeest in a mud hole.
I put in springs from an Unlimited tow package and it corrected that wallow.
1 - 20 of 22 Posts
